clutch pedal
help, the white plastic thingy has broken on my clutch pedal (Octavia 2000, deisel)
how much is the part, the part number, and how much a problem to fit thanks jan:confused:
  • 10 months later...
didi you get yours fixed mine has just done the same
  • 3 years later...
Mine's just done the same on the same car SLX TDI - problem was a broken clutch pedal (common fault). Get a garage to replace pedal and plastic for about £70-£90 all in. Don't be convinced it's the master cylinder or clutch, flywheel etc - if they were fine before they'll still be fine!!
wow major thread revival :giggle:
