1.6 FSI LPG conversion
Hello fellow skoda lovers,
Are there any news in the LPG conversion scene for FSI motors? My engine code is BLFxxxxxxx
I've found that some polaks suceeded in installing LPG system. Something is fishy here :D
I think that there is no point of installing LPG on FSI engine.
AFAIK these direct injection engines need so called 6th generation LPG systems that are rather expensive. The think you talk about might be called the 5th generation - something between the 4th and the 6th. There are designed some systems for the most popular engines and this might be one.
But anyway - even if it's cheaper than the 6th generation, it's still an expensive one. Unless you drive quite a lot, you shouldn't do the conversion.
