Felicia OS Mirror Blind Spot
Hi
Just finding out the little niggles and oddities of living with a new ride. My Fun has a lethal blind spot in the O/S wing mirror, had a couple of close calls already! Got some stick-on convex mirrors in the short term but would rather sort it more subtly. I've pulled the mirror off to see if there was a 'trim' option but to no avail. Has anyone else experienced this? How have you resolved it? Is it a case of fitting aftermarket mirrors?
14 hours ago, RicardoM said:
How is the mirror blind spot solved from factory on your other cars?
Event with full adjustment I can mostly see truckman and have to lean over the gearstick to see overtaking/passing motorway traffic. Just didn't know if all Felicias did this or maybe if my my mirror was faulty/damaged internally/bodged.
You didn't answer my question.
I rephrase it. How do your other stock cars not having a mirror blind spot?
Edited by RicardoM
I thought you'll understand where I'm hinting.
Learn how to adjust your seat and mirrors for not having blind spots.
http://www.caranddriver.com/features/how-to-adjust-your-mirrors-to-avoid-blind-spots
There is nothing wrong with Felicia stock mirrors. It's you not knowing how to adjust them correctly.
The mirrors on other cars have a split section on them that acts as a blindspot mirror. Nothing works better than a glance over your shoulder though (or a slight lean forward and glance over your shoulder in the case of a Pickup).
@KevSunshine You should definitely be able to adjust the mirror out so that you can see more than Truckman. Has your mirror glass been fixed solid?
I can adjust mirrors just fine thanks, been doing it for quite some time.
Sometimes a problem falls outside of the prescribed solution or accepted fixes in a standard situation. I was wondering if my mirrors were:
a) standard
B) damaged
c) fixed/bodged badly
d) had gained sentience, gone evil and were plotting my demise via a traffic 'accident' that would very much be my fault.
e) just a crap design and lots of Felicia owners just swap them for Polo GTI ones; for example.
Kev
Good shout on the split mirror. Might see if I can source a replacement glass to suit. The glass moves with the cable adjust. Maybe retro fitting electric mirrors might help? I can get around it by adjusting driving style/doing 'the lean', but the more I can do to make it safer the better. fitting a more suitable mirror gets it better faster than changing 17 years of driving habit. Not right, but safer, faster = better.
a) standard
B) damaged
For a) to c) it is your job to determine. For d) I recommend a priest. I doubt point e) holds water.
  • Like 2
