Can you enable traffic sign recognition on the SEL
Can you enable TSR function with VCDS on the SEL Exec or doesn't the SEL come with the multifunction camera as standard with certain options disabled. I would of thought it was there for the rain sensing wipers.
As I only ordered my car last week it would be an easy option to add for £85 although this seems cheap if extra hardware was required in this case a rear view mirror with camera in thats whats got me thinking its just a simple turn on at the factory or by VCDS or am I missing something here?
If you have Lane Assist then it should be possible.
The SE L does not have the A5 camera needed as std, TSR is the cheapest option to add so the camera is included.
is there anything else VCDS can add with the camera in place apart from TSR which would have to be paid for to enable me to get the camera without extra modules etc
Only option I have opted for is the RVC, I was going to have the LED+ package but didn't want KESSY tbh so didn't bother in the end
The only ones that spring to mind are:
Lane Assist
Main Beam Assist
Lane Assist
Main Beam Assist
Which involves a simple VCDS intervention only if so well worth me buying VCDS unless I took a day out to come to you ;)
Yes ‘just’ VCDS coding required.
There are a number of VCDS owners in the link in my signature, this would be a much cheaper way of doing it.
Thanks Gizmo
