Coding of drl lights
Hi there.
On the O3 FL, is it possible to code the led drl to turn off when the blinker in that side is activated? It is not the full led version. I think it could look nice.
Pretty sure it's possible, yes. Have a look the in VCDS sticky at the top. You'll need VCDS or OBDeleven to code it though.
3 hours ago, Jonsto said:
Hi there.
If it's a LED Strip is like the Vrs then DRL can be turned off when Indication, The Value needsto be 0% brightness ( I think )
The DRL's on my 230 Vrs dims to 25% brightness when indicating. On my previous Vrs the DRL's flashed alternatly with the Indicator.
