Radiator Bottom Connector leaking
Evening all,
Im hoping someone can help, I've just replaced my radiator after it sprang a leak. When filling the radiator up it has developed a leak on the bottom connector. Just a drip at the moment. Any ideas if these are supposed to have a seal? Or why it could be leaking.
Thanks in advance :)
  • Sponsor
Not 100% sure this is the same on a vRS, but I'll check in a sec:
Yeah, looks to be the same.
Check that the fitting on the new radiator doesn't have any moulding-flash type protruberances that might be interfering with the o-ring's sealing, and if not, replace the o-ring, or try re-seating the connector.
Edited by Wino
