Vrs problem
Hi guys. Having a bit of a problem with my 04 Vrs.
Happened a couple of times where the car would start them cut out straight away as in the Immobilizer cut it out. Usually started after a couple of times trying.
One day it wouldn't start (start and cut out). I removed battery leads for a few mins and it started then. Removed all faults with vcds and was grand for a day or two.
Yesterday after starting Airbag, Abs, traction, Steering and engine lights came on along with flashing handbrake light and speedo not working but it did start and drive.
Removed battery and left it out over night and re fitted it this morning. Cleared all codes and checked the fuses on top of the battery.
Later today it started and cut out twice before running. Engine and Airbag lights on. Cleared them and drove it for a bit. Stopped and started it about 20 times and it was grand.
Any ideas what to check/look out for?
I checked fuses on top of the battery (removed and cleaned them). I checked the battery with a multi meter with engine running and stopped. Also got the battery tested with halfords machine. All was good.
I'll put up pictures of scans and would love to hear any feed back.
Thanks in advance
Sean
Edited by seanw
Id check all the wiring behind the air box first, just a quick visual check to look for splits in the tape etc.
Immo is stored in the clocks and ecu but with the other faults I'd go for wiring around that area, ABS module and ECU are also in that area
Cheers. Will get a look if it stops raining!
Can't see any problem with the wiring.. no sign of any marks or cuts...
