Amundsen - remove SD card music?
31 minutes ago, SWBoy said:
You could always use the method of running the built-in dot_clean command in the Mac Terminal application?
I 'could', if only I knew what I was doing! :thinking:
I've opened the terminal application but have now hit feelings of hopelessness!
Gaz
2 minutes ago, Rjg said:
My Bolero does the same (also on Macbook).
It also has an annoying habit of still displaying tunes that have been deleted in its own little "Trash" folder, which is hidden when I put the SD card in the Mac!
Phew, thought for a minute it was only me!
Gaz
It's been mentioned quite a few times on here - so once you posted images showing Mac files the problem was obvious.
When I browse files on my NAS drive using my Macbook and then again using a PC it's clear just how many (hidden) files the Mac writes into folders.
Now I feel a right numpty :blush:blush
Gaz
I can feel a " Guess the numpty thread "  cropping up    :giggle:
15 hours ago, V6TDI said:
Thanks everyone for the help and suggestions.  Wouldn't have got there without it, and I'm very grateful indeed.
Glad you got it solved :biggrin:
