Window Regulator Replacement
Hi
Nearside window on my wife's 06 vRS is making a grating noise when going up and down which I suspect is caused by a failing window regulator.
Is this the replacement part I need?
http://www.ebay.co.uk/itm/SKODA-FABIA-6Y-MK1-PRAKTIK-FRONT-LEFT-SIDE-WINDOW-REGULATOR-WITH-PANEL-1999-2008-/131708777344?hash=item1eaa747380:g:yd4AAOSw4A5Yx8Pj
If I replace the regulator and panel as a complete unit do I still need the long reach rivet gun?
Mark
That looks like an appropriate part. Although see my question regarding the replacement "clips". IMO if it hasn't completely trashed itself, it may be almost as easy to replace the window clips and save £20+.
To get the carrier off the rivets along the edge must be drilled out. To refit, either use the Skoda rivets and yes, a long lever rivet gun, or use rivnuts or other favoured insert.
Understand now what the rivets are for - they hold the glass to the carrier?
No they hold the Carrier to the door frame.
DB.
Ah - OK, thanks.
Mark
The part number for ancillaries carrier to door rivets is N91078801
They are 6.4mm.
Did this job yesterday - took about 2 hours in total.
Followed the guides on here and all turned out OK.
Hardest bit was getting the rivets in - they are big!
I did this job yesterday too, and used a cheapish 'Silverline' Lazy Tong Riveter which worked well with those VAG 6.4mm rivets. Getting the carrier over the lock-pin and then manouvering the top of the regulator into the door was awkward though!
Glad you got it all sorted :biggrin:!
Edited by garibaldy
Hi if anyone else is doing this job i can supply the correct size rivets for far less than vw... msg me if intetested. and yes, they certainly are big!
