Fabia VRS Clocks backlight not working?
As stated, my clocks back light dosent work? is this a fuse of something different?
I cant see the clocks at all at night!
Any possible solutions would be appreciated
Have you still got Reg plate bulbs and all side lights?
check them and if some of them are off it will be a fuse.
if everything els works apart from the clocks it might be somthing els
  • Sponsor
Brightness thumb wheel accidentally spun to minimum?
Every other bulb works, No warning lights about a bulb out either.
That's fine, They just dont work
Well if you can't find out anything els and get stuck, I can test the clocks for you.
Where about are you based mate? are you coming down to the dubfiction show this weekend?
I'm in Newcastle, sadly not I'm at NE1 Scene this weekend.
Man no worries then mate, you'll have to let me know for you're down this Way!
I can talk you through other ways of testing the wiring loom if you have a test light. or post me your clocks and I'll check them / make chances for you :D
or... go to a scrap yard or somthing and test fit any other Fabia clocks to see if they light up.
think that's covered all angles :D
I do actaully have another set of clocks, so ill try that first and if not ill get back to you!
