Headlight switch and power feed
Just doing a slight mod to some dashboard lighting bit don't have the car here at the minute to check but need to plan on wiring routing etc
Is it still the same procedure for removing the headlight switch as fabia 2
Also is the blue and white wire the dash lighting feed for when the lights are turned
Is there also an earth at the switch
Thank you in advance
Ok so no takers then
Is the switch removable the same as f2
 push and pull on side lights position
Yes. Push in, turn clockwise and pull
I added the W8 light unit, I took feed off the headlamp levelling switch as it was easier to work out which was the interior lighting pin. Pop the end of the dash off with a trim removal tool (same as getting to the fuse box on many other VAG cars) and it's all really accessible.
