Central locking problems (driver doors)
Hi everyone,
As most of the skoda octavia mk1 owners, I have problem with not working remote lock/unlock on driver doors :D It locks only with a key, locking all other doors, led starts to blink. Both in L or R position, I can only control left mirror. Have read all topics related to this, but just wanted to see which of the pins should feed 12V, and which should be 0. So maybe someone of you has wiring diagrams, pinouts of everything from central locking unit to driver doors? Including window lift motor and etc. Guess it will be some broken wires. Thank you. :)
Give this a read. It will explain a lot.
Yeah it can explain something for others, but I have read this and other related topics in our forum several times and I understand how things there work. I would appreciate if someone could post some wiring diagrams if someone has it (because I can't find anything on the internet). I need wires colors, pins, voltage on them.:)
From what you've said, it will be either the corroded pin in the bottom of the window motor, or a snapped wire in the rubber boot between door and car.
