Can you fit an Octavia towbar on a Superb?
Lads
I probably know the answer. But I have factory fit towbar on the Octavia VRS. Would it be possible to swap that to the new Superb I've coming?
How easy of a job could it be?
If you look up the Westfalia tow bar from PF Jones for the Octavia, note the part number and see if it is the same for the Superb you will have your answer. However you will need to add the crossmember back to the Octavia which is removed is replaced by the tow bar frame, not sure if you will have this if it was factory fitted. The dedicated electrics it is better to fit new ones than spend the time and expense of removing them from the Octavia.
If you don't have the crossmember I'd imagine Skoda will rob you blind for one and most likely more than getting a tow bar.
Thank you for that.
