2012 Vrs Water pump Leaking
Previous cars were fixed, this last one is at a Dealership for sale with no warning lights on.
I do not feel guilty as they are selling it with a Warranty & Roadside Assistance.
If the EML is flickering then suspect a connection or the Cat on the way out, lambda sensor etc etc,
it is a minefield which is why i suggested a Main Dealer with a quality Master Tech doing the water pump.
Yeah this could come back to bite me In the ass, I've read several posts now on the missfires and nobody seems to have a soloution?
I did use regular unleaded the day the EML came on, I've now put a full tank of BP ultimate in it...Spark plugs are ordered. Will try get a compression done at the weekend.
Im hoping it's plugs or coil pack.
BP Ultimate Super Unleaded is 97 ron, like Sainsburrys, ESSO and other Super Unleaded.
If you want 99 ron then use Tesco Momentum 99 or Shell V-Power Nitro+ if needs must.
Sorry for spamming  threads.
Car is now Error and leak free, Problem with EML was found to be a missfire in cylinder one due to a dud spark plug, Fittes some denso's and it seems to be running fine as of now.
My V20 denso's came gapped at 0.4mm......tested them at that and they work fine so they can stay like that.
Will try get a pc up of the faulty plug .
