Vrs front suspension knock
Hi all
My 2003 vrs has had a loud knock for a few weeks gradually getting worse on the n/s up high.
I have had the car up on the ramp at work and couldn't find any split bushes etc. So I removed the strut to find the damper had no oil and the strut top mount worn out with loads of play, I have bought a full set of bilstein b4 and a pair of front top mounts. I have fitted them on the n/s and the noise is still there!
The only other thing I found is my bottom ball joint had a small split now a big one but I doubt this is the cause.
Does anyone have any ideas?
Is there anything behind the arch liner?
  • Sponsor
Or ARB bush, undo one end of the droplink on the knocking side and see how much play the bar has in the bush. I was surprised recently when an ever-worsening knock turned out to be this. I was intending to swap out the droplink as the easiest thing to try, but once the anti-roll bar was loose it moved loads within the bush, and made a familiar noise as it did. The bush was quite recent, but the shocks are original (150k old), and I have a feeling (without theoretical understanding) that a worn out old shock may allow fast, small movements that a newer one wouldn't, putting much more force on anything connected?
Brilliant thanks guys I will give the arb bushes a proper test tomorrow as Wino suggests and if they turn out to be fine I will replace the droplinks.
