Audi 2012 S3 - single press unlock all doors
Today I tried coding a 2012 Audi S3 to unlock all the doors with a single press of the button, it's worked on everycar I've tried but although the coding was accepted it didn't work.
I went into 09 central electrics and did the usual single door locking options on coding, then checked on adaption.
I got no response from 46 central convenience controller so take it it isn't edited in that.
what am I doing wrong?
thanks
thanks
I'm surprised that you need to code this operation.
My 2012 Superb gives me 3 options re. locking / unlocking in the Maxidot, under Settings / Convenience / Central Locking.
Since it 'tis but an 'umble Skoda I'm surprised that said options  aren't available in an Audi S3..............
DC
If its any use, my fabia had a problem with the module 46 and it said there was no response from controller, couldn't code anything for the central locking as a result. I had to disconnect the battery for 10 mins then reconnect so the module could reset itself and be read again.
I don't know whether that might be the case or whether it just doesn't have the module fitted.
  • Sponsor
Didn't the Central Convenience module get merged into BCM at some point in history? Don't ask me when, but I'd be surprised if a 2012 car had a separate module 46, does an autoscan try to talk to it?
They did yeah, but it did show up on the "installed list" just got no communication.
ive also coded a 2012 Audi Q7 and 2012 Fabia today which all worked fine (2012 coding day :D )
