Headlights upgrade from halogen to bi-xenon (with LED DRL) - coding!
tygger
hi all,
i've recently upgraded my halogen headlights to bi-xenons with led drl (octavia mk3 my2016). self-leveling was also installed, but not yet active, because i need a new high can gateway for this function (mid installed by factory, new one will be installed by official skoda dealer).
with the fabulous help from aki78 i have the vcds coding for the upgrade (without afs codes). this guide works fine in my car without no major fault code, but of course YOU CAN USE IT AT YOUR OWN RISK ONLY. i still have a low priority fault code (540693 - Databus U1121 00 [009] - Missing Message), this is maybe because of the lack of communication between the car and the already installed afs modules. please keep this in mind!
here is the coding:
1. DISABLE HALOGEN LEFT HIGH BEAM
(1)-Leuchte8FL LB39-Lasttyp 8 to not active
(2)-Leuchte8FL LB39-Lampendefektbitposition 8 to 00
(3)-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 to 00
(4)-Leuchte8FL LB39-Lichtfunktion A 8 to not active
(5)-Leuchte8FL LB39-Lichtfunktion B 8 to not active
(6)-Leuchte8FL LB39-Dimmwert AB 8 to 0
2. DISABLE HALOGEN RIGHT HIGH BEAM
(1)-Leuchte9FL RB2-Lasttyp 9 to not active
(2)-Leuchte9FL RB2-Lampendefektbitposition 9 to 00
(3)-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 to 00
(4)-Leuchte9FL RB2-Lichtfunktion A 9 to not active
(5)-Leuchte9FL RB2-Lichtfunktion B 9 to not active
(6)-Leuchte9FL RB2-Dimmwert AB 9 to 0
3. LEFT BI-XENON HEADLIGHT
(1)-Leuchte6ABL LC5-Lasttyp 6 to 3 - Xenon Abblendlicht
(2)-Leuchte6ABL LC5-Lampendefektbitposition 6 to 36
(3)-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 to 1A
(4)-Leuchte6ABL LC5-Lichtfunktion A 6 to Abblendlicht links
(5)-Leuchte6ABL LC5-Lichtfunktion B 6 to Lichthupe generell
(6)-Leuchte6ABL LC5-Dimmwert AB 6 to 127
(7)-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 to Always
(8)-Leuchte6ABL LC5-Lichtfunktion C 6 to Coming Home oder Leaving Home aktiv
(9)-Leuchte6ABL LC5-Lichtfunktion D 6 to not active
(10)-Leuchte6ABL LC5-Dimmwert CD 6 to 127
4. RIGHT BI-XENON HEADLIGHT
(1)-Leuchte7ABL RB1-Lasttyp 7 to 3 - Xenon Abblendlicht
(2)-Leuchte7ABL RB1-Lampendefektbitposition 7 to 40
(3)-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 to 1B
(4)-Leuchte7ABL RB1-Lichtfunktion A 7 to Abblendlicht rechts
(5)-Leuchte7ABL RB1-Lichtfunktion B 7 to Lichthupe generell
(6)-Leuchte7ABL RB1-Dimmwert AB 7 to 127
(7)-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 to Always
(8)-Leuchte7ABL RB1-Lichtfunktion C 7 to Coming Home oder Leaving Home aktiv
(9)-Leuchte7ABL RB1-Lichtfunktion D 7 to not active
(10)-Leuchte7ABL RB1-Dimmwert CD 7 to 127
5. LEFT BI-XENON "SHUTTER"
(1)-Leuchte10SHUTTER LB23-Lasttyp 10 to 2 - Shutter; Diagnosesensierung für 'LED low'
(2)-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 to 37
(3)-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 to 1E
(4)-Leuchte10SHUTTER LB23-Lichtfunktion A 10 to Left high beam
(5)-Leuchte10SHUTTER LB23-Lichtfunktion B 10 to Lichthupe generell
(6)-Leuchte10SHUTTER LB23-Dimmwert AB 10 to 127
6. RIGHT BI-XENON "SHUTTER"
(1)-Leuchte11SHUTTER RB22-Lasttyp 11 to 2 - Shutter; Diagnosesensierung für 'LED low'
(2)-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 to 41
(3)-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 to 1F
(4)-Leuchte11SHUTTER RB22-Lichtfunktion A 11 to Right high beam
(5)-Leuchte11SHUTTER RB22-Lichtfunktion B 11 to Lichthupe generell
(6)-Leuchte11SHUTTER RB22-Dimmwert AB 11 to 127
7. LEFT FRONT SIDELIGHT (BI-XENON + PARKING LIGHT)
(1)-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 to 8 - allgemeine Glühlampe 12W
(2)-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 to 35
(3)-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 to 17
(4)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 to Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 to Parklicht links (beidseitiges Parklicht aktiviert li & re)
(6)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 to 100
8. RIGHT FRONT SIDELIGHT (BI-XENON + PARKING LIGHT)
(1)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 to 8 - allgemeine Glühlampe 12W
(2)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 to 3F
(3)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 to 19
(4)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 to Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 to Parklicht rechts
(6)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 to 100
9. LEFT LED DRL (+SIDELIGHT AND PARKING LIGHT)
(1)-Leuchte2SL VLB10-Lasttyp 2 to 4 - LED Tagfahrlichtmodul Signal
(2)-Leuchte2SL VLB10-Lampendefektbitposition 2 to 48
(3)-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 to 4A
(4)-Leuchte2SL VLB10-Lichtfunktion A 2 to Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte2SL VLB10-Lichtfunktion B 2 to Parklicht links (beidseitiges Parklicht aktiviert li & re)
(6)-Leuchte2SL VLB10-Dimmwert AB 2 to 35
(7)-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 to Always
(8)-Leuchte2SL VLB10-Lichtfunktion C 2 to Coming Home oder Leaving Home aktiv
(9)-Leuchte2SL VLB10-Lichtfunktion D 2 to not active
(10)-Leuchte2SL VLB10-Dimmwert CD 2 to 35
(11)-Leuchte2SL VLB10-Dimming Direction CD 2 to maximize
(12)-Leuchte2SL VLB10-Lichtfunktion E 2 to Daytime running lights
(13)-Leuchte2SL VLB10-Lichtfunktion F 2 to not active
(14)-Leuchte2SL VLB10-Dimmwert EF 2 to 127
10. RIGHT LED DRL (+SIDELIGHT AND PARKING LIGHT)
(1)-Leuchte3SL VRB21-Lasttyp 3 to 4 - LED Tagfahrlichtmodul Signal
(2)-Leuchte3SL VRB21-Lampendefektbitposition 3 to 4C
(3)-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 to 4C
(4)-Leuchte3SL VRB21-Lichtfunktion A 3 to Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte3SL VRB21-Lichtfunktion B 3 to Parklicht rechts
(6)-Leuchte3SL VRB21-Dimmwert AB 3 to 35
(7)-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 to Always
(8)-Leuchte3SL VRB21-Lichtfunktion C 3 to Coming Home oder Leaving Home aktiv
(9)-Leuchte3SL VRB21-Lichtfunktion D 3 to not active
(10)-Leuchte3SL VRB21-Dimmwert CD 3 to 35
(11)-Leuchte3SL VRB21-Dimming Direction CD 3 to maximize
(12)-Leuchte3SL VRB21-Lichtfunktion E 3 to Daytime running lights
(13)-Leuchte3SL VRB21-Lichtfunktion F 3 to not active
(14)-Leuchte3SL VRB21-Dimmwert EF 3 to 127
11. LEFT DRL POWER (+SIDELIGHT AND PARKING LIGHT)
(1)-Leuchte4TFL LB4-Lasttyp 4 to 1 - LED Tagfahrlichtmodul Versorgung
(2)-Leuchte4TFL LB4-Lampendefektbitposition 4 to 3A
(3)-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 to 49
(4)-Leuchte4TFL LB4-Lichtfunktion A 4 to Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte4TFL LB4-Lichtfunktion B 4 to Parklicht links (beidseitiges Parklicht aktiviert li & re)
(6)-Leuchte4TFL LB4-Dimmwert AB 4 to 127
(7)-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 to Always
(8)-Leuchte4TFL LB4-Lichtfunktion C 4 to Coming Home oder Leaving Home aktiv
(9)-Leuchte4TFL LB4-Lichtfunktion D 4 to not active
(10)-Leuchte4TFL LB4-Dimmwert CD 4  to 127
(11)-Leuchte4TFL LB4-Dimming Direction CD 4 to maximize
(12)-Leuchte4TFL LB4-Lichtfunktion E 4 to Daytime running lights
(13)-Leuchte4TFL LB4-Lichtfunktion F 4 to not active
(14)-Leuchte4TFL LB4-Dimmwert EF 4 to 127
12. RIGHT DRL POWER (+SIDELIGHT AND PARKING LIGHT)
(1)-Leuchte5 TFL RB32-Lasttyp 5 to 1 - LED Tagfahrlichtmodul Versorgung
(2)-Leuchte5 TFL RB32-Lampendefektbitposition 5 to 44
(3)-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 to 4B
(4)-Leuchte5 TFL RB32-Lichtfunktion A 5 to Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte5 TFL RB32-Lichtfunktion B 5 to Parklicht rechts
(6)-Leuchte5 TFL RB32-Dimmwert AB 5 to 127
(7)-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 to Always
(8)-Leuchte5 TFL RB32-Lichtfunktion C 5 to Coming Home oder Leaving Home aktiv
(9)-Leuchte5 TFL RB32-Lichtfunktion D 5 to not active
(10)-Leuchte5 TFL RB32-Dimmwert CD 5 to 127
(11)-Leuchte5 TFL RB32-Dimming Direction CD 5 to maximize
(12)-Leuchte5 TFL RB32-Lichtfunktion E 5 to Daytime running lights
(13)-Leuchte5 TFL RB32-Lichtfunktion F 5 to not active
(14)-Leuchte5 TFL RB32-Dimmwert EF 5 to 127
Edited by tygger
it turned out that in my car double shutter coding is needed
maybe this is a bug, but now works fine with this:
1. MODIFY HALOGEN LEFT HIGH BEAM CODING
(1)-Leuchte8FL LB39-Lasttyp 8 to 2 - Shutter; Diagnosesensierung für 'LED low'
(2)-Leuchte8FL LB39-Lampendefektbitposition 8 to 37
(3)-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 to 1E
(4)-Leuchte8FL LB39-Lichtfunktion A 8 to Left high beam
(5)-Leuchte8FL LB39-Lichtfunktion B 8 to Lichthupe generell
(6)-Leuchte8FL LB39-Dimmwert AB 8 to 127
2. MODIFY HALOGEN RIGHT HIGH BEAM CODING
(1)-Leuchte9FL RB2-Lasttyp 9 to 2 - Shutter; Diagnosesensierung für 'LED low'
(2)-Leuchte9FL RB2-Lampendefektbitposition 9 to 41
(3)-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 to 1F
(4)-Leuchte9FL RB2-Lichtfunktion A 9 to Right high beam
(5)-Leuchte9FL RB2-Lichtfunktion B 9 to Lichthupe generell
(6)-Leuchte9FL RB2-Dimmwert AB 9 to 127
Hi tygger,
info provided looks very useful.
Just wanted to check related to swap, you have just removed halogen ones and bolted LED/xenon ones and plugged-in existing cable?
No other modification than SW ones are needed?
6 minutes ago, dejan011 said:
Hi tygger,
hi, unfortunetely you'll need adapters like this: https://www.cars-equipment.com/en/shop/head-lights-xenon-autoleveling-8/xenon-head-lights-adapters-for-skoda/
10 minutes ago, dejan011 said:
Thanks tygger for prompt reply!
So apart from those adapters and codding - they are plug and play?
well you need to check whether your bcm supports xenon or not. it's 50-50 and if not, it's hard to change because of component protection. i was lucky enough to have a factory fitted bcm that supports xenon. check your 09 module with VCDS (long coding) and verify if it's compatible with xenons. if you see something like 'xenon shutter not ssupported by this control module' you need to buy a new one. i also needed to change the can gateway, also component protected, coding was done by an official skoda dealer. you need to have a bcm (or similar): PQ37BOSCH (5Q0-937-086-AK), a 'high' can gateway (or similar): 5Q0-907-530-F, and you will also need a headlight range module (or similar): 7P6-907-357-A. you will also need to install front and back auto leveling sensors, so to be honest it's a very complex project
Edited by tygger
Hello, are you able to help me with following. I would like to activate slowly dimming of LED day lights after using sidelights (the white strips on bootom side of headlights, which are changed at orange during using sidelights). There are many instruction for this topic related with Fabia MK3, Superb MK3 and Octavia MK3 as well, but described modification only for model before facelift (adaptation on: Leuchte2SL VL B10 and Leuchte2SL VR B21), But this instruction doesn´t working on Octavia MK3 facelift with LED headlights, because of B10  and B20 are not active. Is there anybody who tried to do it on OctaviaMK3 facelift with LED headlights?
sorry, i can't help in this :(
Hello tygger, thanks for fast reaction. I have codding/adaptatation chart for my car so I will try it and I will inform you about result if you want. B.R. Michal
  • 11 months later...
Hello Guys.
I just did the similar exchange (from Xenon to Xenon/LED) as #tygger described above. I followed all VCDS coding but side light does not work. Non of the sides. However according to the perfect coding description it should. Can anybody help? Thanks a lot. Akos
  • 3 years later...
On 12/2/2020 at 21:05, Collinger said:
Hola, chicos.
Acabo de hacer un intercambio similar (de Xenon a Xenon/LED) como #tygger descrito anteriormente. Seguí toda la codificación VCDS pero la luz lateral no funciona. No de los lados. Sin embargo, de acuerdo con la descripción de codificación perfecta, debería hacerlo. ¿Alguien puede ayudar? Muchas gracias. akos
I have the same problem.
Any help?
