Drivers window juddering on way down
The drivers side window judders on the way down, also sometimes stops on the way down.  Up is fine.  I suspect the runners are too tight inhibiting its easy movement, might try and lube them with silicon spray. Could be something else though?
Does anyone have this issue?
Same here!
I've experienced it before (not on the current model) but more so after a very dry weather spell when dust got in.  You could be right about the cause and spray can work but make sure you take it back to the dealer anyway just in case there is anything else blocking its movement and it causes damage to the window itself.  Hope you're happy enough with the car otherwise.
Edited by Superb170
