Rear Screen Dash Cam with Panoramic Sunroof
Made a few enquires today about having a front and rear dash cam Installed but most firms have said the wire to the rear screen can't go into the headlining because of the Pan roof, the wires to the rear camera will be visible. Has any one with a Panoramic Sunroof fitted/or had fitted the wire into the headlining.  Also does the wiring need a suppressor for the Dab radio.
Thanks in advance
AG
Anyone?
Why not have separate cameras front and rear. I have independent cameras fitted, front one wired into the fuse box and the rear powered by the rear power socket - which needs to be set to power only with ignition. Each has its own memory card and both are 1080p with GPS, often with dual cameras the rear is only 720p.
As above, why not buy a cheap ~£40 cam for the rear and wire it to the boot 12v socket?
Edited by Orville
