CR170 - Intermittent power steering problem & 01598 - Drive Battery Voltage - 011 - Open Circuit - Intermittent
2 hours ago, Muzza80 said:
Thought I'd update this, sorted it a while ago now, was down to a bad/loose earth connection from gearbox to chassis under the battery tray, cleaned up the connection points and tightened it all up, problem has never returned!
Good info. Glad it's sorted.
  • 5 weeks later...
Hi muzza80 can u plz help me, i am facing same problem in skoda octavia ii. I have even replaced the battery to new. It has 13V-12.8 without ignition and 14 or above with engine on .
I have even cleaned sanned the ground which you are talking in the above post.
I have checked and cleaned other 3 grounds also.
Plz suggest what i should do
