Remote fob kessey system
I have 2 fobs one gives audible alarm when used and one doesn't on my superb any ideas
Change settings in maxi dot for the key that doesn't beep after opening car with that key maybe
Ok will try and let you know I want to stop the one from beeping though i will have a look
Yes, as mentioned. When the beep is turned off, it only does it for that key. Had exactly the same a couple of weeks back when I used my spare key instead of the usual one, and for a short time wondered what the car was trying to tell me.
Did not know that you could turn off the beep :blush
It's strange really, because the beep is off by default anywhere in Europe because its not allowed to be on under European law. Some manufacturers interpret that as never being allowed to be on, where Skoda sell it with it switched off but allow you to switch it on after sale.
But how do I switch it off
Try this
"In the maxidot there is only one option regarding the alarm, under "Comfort" in "Settings", but this only turns on or off the short beep which sounds when the alarm is switched on or off"
Looked at maxi dot no comfort in setting only convenience only options one door or all doors any other ideas
In the settings the option for beeps on arm/disarm is called "ATA Confirm".  ATA means anti-theft alarm.
Hello all sorted did find ata and switched the bleep off thanks to everyone for the information great forum to be in
