Bluetooth troubles
Picked up my first ever skoda octavia it's a 2010 20ltr tdi Lauren and klement I'm having trouble with the bluetooth on the radio it has the option but it's not lit up I've tried paring a s4 and iphone 5s but nothing is happening.
Could you help
Usually, module is not present as standard unless L&K different.
Oh ok where is the module situated and where can I buy one from is it a skoda part the radio is a belero
Factory fit module is under driver's seat under plastic cover. If it's there it'll be obvious. On a 2010 model the factory fit Bluetooth was rSap only so even if it is there to use with your iPhone you'll need to replace the module.
Yeah there is no module under the seat :/
