1.9 ever delete
Hello friends,
I own a MK2 Fabia 1.9 TDI with the BLS engine and am currently looking for a way to block the egr valve. I have seen various videos on YouTube but in those, the egr valve is always controlled via a pneumatic actuator (vacuum cell). Does anybody know how to do this with the egr valve of the 1.9 TDI BLS engine? Also I wanted to inquire as to whether the car goes into limp mode or not after deleting the egr.
Thank you everyone for your help.
I removed mine, fitted the blanking plate to the turbo and put the straight pipe connector in its place.
i remapped mine to get rid of the engine management light but other than that you should be fine
 Dependant on your ECU, the following may be suitable, hutchysrs50 may be able to confirm if its the EDC15 on the Mk2.
Thats right, the early 1.9 engine Mk2 Fabias use EDC15 plus (EDC15+)
Unrelated to the OP but for search reasons the 1.6 diesels and newer Mk2 Fabias they use EDC17 and the above method doesn’t work. :)
Edited by hutchysrs50
Thank you so far for your replies, there's obviously a lot i wasn't aware of :)
