Gearbox
Any idea if any other octavia model box would fit my mk1 vrs? Or equally would a say mk iv golf/gti/r32 box fit?? Would the part numbers be the same across the vag cars, would be the handiest way of checking i reckon...
When you ask ths fella at the breakers will something fit surprisingly the answer is ALWAYS yes:)
Have a guy with a box said it would fit mine
He said its an EVS code mk4 platform 1.8t box
That sound like right box?
Also said he bought it from guy who said was a known good box and its 50 smackers which is good value in ireland
Well it will probably fit, but that box is specced for the AGU and AUM engine codes on the Octavia. I would expect the gear ratios to be fractionally different, but if you can give me 2 or 3 hours, I'll come back with some ratio info for you to be sure.
The big thing for the fit point of view is that the first motion shaft has the same number of splines to fit the clutch plate in your car now.
As I mentioned earlier -
Identification characters, aggregate assignment, ratios, capacities
  Note
t  Modified gearshift mechanism on the gearbox side as of 05.99 → Chapter.
t  Modified synchronization for the 1st gear as of 09.00 → Chapter.
Identification characters CZL CZM DBZ
Assignment: Engine 1.9 ltr./66 kW TDI 1.8 ltr./92 kW 1.8 ltr./110 kW
Ratio: Final drive 62 : 17 = 3,647 72 : 17 = 4,235 70 : 19 = 3,684
Z 2 : Z 1 1st gear 33 : 10 = 3,300 33 : 10 = 3,300 33 : 10 = 3,300
  2nd gear 35 : 18 = 1,944 35 : 18 = 1,944 35 : 18 = 1,944
  3rd gear 34 : 26 = 1,308 34 : 26 = 1,308 34 : 26 = 1,308
  4th gear 33 : 36 = 0,917 35 : 34 = 1,029 35 : 34 = 1,029
  5th gear 33 : 46 = 0,717 36 : 43 = 0,837 36 : 43 = 0,837
  Reverse gear 17 : 10 x 36 : 20 = 3.060
  Speedometer 13 : 22 = 0,591
Capacity 2,0
Specification → Electronic Catalogue of Original Parts
Gear oil change interval Filled for life
Clutch control hydraulic
Clutch disc diameter Ø → Electronic Catalogue of Original Parts
Drive shaft flange Ø 100 mm
Identification characters DEA DQY DTK
Assignment: Engine 1.9 ltr./81 kW TDI 1.9 ltr./66 kW TDI 1.8 ltr./110 kW
Ratio: Final drive 61 : 18 = 3,389 61 : 18 = 3,389 70 : 19 = 3,684
Z 2 : Z 1 1st gear 34 : 9 = 3,778 34 : 9 = 3,778 33 : 10 = 3,300
  2nd gear 33 : 16 = 2,063 36 : 17 = 2,118 35 : 18 = 1,944
  3rd gear 31 : 23 = 1,348 34 : 25 = 1,360 34 : 26 = 1,308
  4th gear 29 : 30 = 0,967 34 : 35 = 0,971 35 : 34 = 1,029
  5th gear 30 : 39 = 0,769 34 : 45 = 0,756 36 : 43 = 0,837
  Reverse gear 18 : 9 x 36 : 20 = 3.600 18 : 9 x 36 : 20 = 3.600 17 : 10 x 36 : 20 = 3.060
Capacity 2,0
Identification characters DYP EBF EBJ
Assignment Engine 1.8 ltr./110 kW 1.9 ltr./81 kW TDI 1.9 ltr./66 kW TDI
Ratio: Final drive 70 : 19 = 3,684 61 : 18 = 3,389 61 : 18 =∼3,389
Z 2 : Z 1 1st gear 33 : 10 = 3,300 34 : 9 = 3,778 34 : 9 = 3,778
  2nd gear 35 : 18 = 1,944 33 : 16 = 2,063 36 : 17 = 2,118
  3rd gear 34 : 26 = 1,308 31 : 23 = 1,348 34 : 25 = 1,360
  4th gear 35 : 34 = 1,029 29 : 30 = 0,967 34 : 35 = 0,971
  5th gear 36 : 43 = 0,837 30 : 39 = 0,769 34 : 45 = 0,756
  Reverse gear 17 : 10 x 36 : 20 = 3.060 18 : 9 x 36 : 20 = 3.600 18 : 9 x 36 : 20 = 3.600
Capacity 2,0
Drive shaft flange Ø 100 mm 108 mm 100 mm
Identification characters EBN ECW EGR
Assignment: Engine 1.8 ltr./110 kW 1.8 ltr./110 kW 1.9 ltr./66 kW TDI
Ratio: Final drive 70 : 19 = 3,684 70 : 19 = 3,684 61 : 18 = 3,389
Z 2 : Z 1 1st gear 33 : 10 = 3,300 33 : 10 = 3,300 34 : 9 = 3,778
  2nd gear 35 : 18 = 1,944 35 : 18 = 1,944 36 : 17 = 2,118
  3rd gear 34 : 26 = 1,308 34 : 26 = 1,308 34 : 25 = 1,360
  4th gear 35 : 34 = 1,029 35 : 34 = 1,029 34 : 35 = 0,971
  5th gear 36 : 43 = 0,837 36 : 43 = 0,837 34 : 45 = 0,756
  Reverse gear 17 : 10 x 36 : 20 = 3.060 17 : 10 x 36 : 20 = 3.060 18 : 9 x 36 : 20 = 3.600
Capacity 2,0
Drive shaft flange Ø 108 mm 108 mm 100 mm
Identification characters EGS EGU EGY
Assignment: Engine 1.9 ltr./81 kW TDI 2.0 ltr./82 kW 1.8 ltr./110 kW
Ratio: Final drive 61 : 18 = 3,389 71 : 18 = 3,944 70 : 19 = 3,684
Z 2 : Z 1 1st gear 34 : 9 = 3,778 33 : 10 = 3,300 33 : 10 = 3,300
  2nd gear 33 : 16 = 2,063 35 : 18 = 1,944 35 : 18 = 1,944
  3rd gear 31 : 23 = 1,348 34 : 26 = 1,308 34 : 26 = 1,308
  4th gear 29 : 30 = 0,967 35 : 34 = 1,029 35 : 34 = 1,029
  5th gear 30 : 39 = 0,769 36 : 43 = 0,837 36 : 43 = 0,837
  Reverse gear 18 : 9 x 36 : 20 = 3.600 17 : 10 x 36 : 20 = 3.060 17 : 10 x 36 : 20 = 3.060
Capacity 2,0
Drive shaft flange Ø 100 mm 100 mm 108 mm
Identification characters EHA EMR ENJ
Assignment: Engine 1.8 ltr./132 kW 2.0 ltr./85 kW 1.8 ltr./110 kW
Ratio: Final drive 62 : 17 = 3,647 71 : 18 = 3,944 70 : 19 = 3,684
  4th gear 30 : 29 = 1,034 35 : 34 = 1,029 35 : 34 = 1,029
  5th gear 31 : 37 = 0,838 36 : 43 = 0,837 36 : 43 = 0,837
  Reverse gear 17 : 10 x 36 : 20 = 3.060 17 : 10 x 36 : 20 = 3.060 17 : 10 x 36 : 20 = 3.060
Capacity 2,0
Drive shaft flange Ø 108 mm 100 mm 108 mm
Identification characters EUH EVS FBX
Assignment: Engine 1.9 ltr./74 kW TDI PD 1.8 ltr./110 kW 1.8 ltr./110 kW
Ratio: Final drive 61 : 18 = 3,389 70 : 19 = 3,684 70 : 19 = 3,684
  5th gear 29 : 39 = 0,744 36 : 43 = 0,837 36 : 43 = 0,837
Capacity 2,0
Drive shaft flange Ø 100 mm 108 mm 108 mm
Identification characters JDH JDM JDP
Assignment: Engine 1.9 ltr./74 kW TDI PD 1.9 ltr./66 kW TDI 1.8 ltr./110 kW
  5th gear 29 : 39 = 0,744 34 : 45 = 0,756 36 : 43 = 0,837
  Reverse gear 36 : 20 x 18 : 9 = 3.600 36 : 20 x 18 : 9 = 3.600 36 : 20 x 17 : 10 = 3.060
  Speedometer 13 : 22 = 0,591 13 : 22 = 0,591 electronic
Capacity 2,0
Identification characters JDW JEG
Assignment: Engine 2.0 ltr./85 kW 1.8 ltr./110 kW
Ratio: Final drive 71 : 18 = 3,944 70 : 19 = 3,684
  3rd gear 34 :26 = 1,308 34 : 26 = 1,308
  Reverse gear 36 : 20 x 17 : 10 = 3.060 36 : 20 x 17 : 10 = 3.060
  Speedometer 13 : 22 = 0,591 electronic
Capacity 2,0
Great info there from @kentphil1:)
The VRS should have an EHA 'box. Presumably the replacement will need to have the same drive shaft flange diameter (108mm)?
Most of the other gearboxes for 1.8 engines have similar ratios to the EHA one. I wouldn't fit a diesel 'box as the ratios are longer and the VRS ratios seem long to me already.
Thanks a mil for looking that up for me Phil. So going by that info the EVS code and the EHA are practically identical, slight difference in ratios in 4th and 5th gear. Both have 108mm shaft size so it would be ok
What do the ratios actually refer to. Is it gear sizes? Sorry no experience with this...
Another guy closer to home said he also has a box would do, will find out what code it is.
Theres couple of vids on youtube of remove and replace the clutch,both on VW,  will look on here for a guide also
According to @kentphil1 info above the EVS and EHA are both 108mm. What do the ratios refer to about each gear?? Ill give it a google:)
This explains it quite well:
https://en.wikipedia.org/wiki/Gear_train#Example_2
Gotcha! thanks again:)
sent a pm to Groupvrs1 also about a conversion to SMF and G60 flywheel after reading another thread on here. seems to be a popular change up for the clutch and from what i can tell a better value route to go with it. so be interesting to see what he has to say!
14 hours ago, huwants2no said:
I wouldn't touch either of those - they don't seem to list what brand the parts are. Have a search for other threads on SMF conversions - it has been well covered before.
Has the clutch been replaced before? Why not keep the DMF and just replace the clutch? DMF failures on 1.8Ts seem to be quite rare.
The 2nd one is National. Just what folks were saying about while there mite as well do flywheel. Its got 185k miles on it
  • john999boy changed the title to Gearbox
23 hours ago, huwants2no said:
Anyone know if this tool will work replacing clutch in mk1 vrs octy
http://www.halfords.ie/webapp/wcs/stores/servlet/ProductMobileDisplay?storeId=11101&productId=203553&srch=Clutch+allignment&categoryId=317962&langId=-1&catalogId=15551
Am going with a conversion kit to smf if that makes any difference
Guys has anyone used one of these tools doing the clutch. Says for single plate clutches and ones with no pilot bearing!??
ok.have the parts to go in...regarding the driveshafts in making room to take out the transmission do I just unbolt the 6 bolts on each shaft at the engine end of them or do I need to completely remove the shafts or maybe the passenger side shaft?
Its the one bit on a few different videos Ive watched thats not 100% clear...can someone explain a bit whats best way to go. I know a lot of guys on here have done the clutch!!
thanks
