Grinding noise from front wheel area
Not had a good look yet as its dark, but any pointers about what this could be.......I get a grinding noise from front drivers side wheel, at first I thought it might be a stone around discs/brakes but not so sure now. It gets worse turning right and virtually goes way turning left....pads look good.
If this happened suddenly, it should be stone indeed. Squeak from it is very loud.
Had this happen on. You old honda CRV, turned out to be the front brake back plate had come loose and was grinding away on the disc. Very loud and grinding noise.
Turns out it was a stone had got trapped behind disc......first time in over 30yrs driving had this happen!!!
Easy fix. Just want you need this time of year.
You are so right!! :biggrin:
