Affordable VAG fault code reader with ABS-functionality?
I need a reader that can figure out the ABS error on my 2000 Octavia. Any suggestion for an affordable reader that works with this car and ABS? I have an ELM237 BT OBD reader but I can't use this to read ABS codes?
Any experience with a reader for this car?
Nope...
Might be worth adding where you are as you might find a local member with VCDS is willing to help :)
i don't see why this wouldn't, I use the VS550 and I can go into most options.
so for reading a ABS related code, yes it will work
Thanks, VS550 then.
  • 1 year later...
 Vgate VS450 works perfectly for reading and deleting ABS-codes.
