RCD330 working with Skoda sound system?
Hello everyone
I have a 2006 Škoda Octavia II (preFL 1.9TDI)
I have a Skoda columbus head unit in my car; My car has a factory fitted DSP with the 12-speaker sound system. Here is a picture of the DSP:
I am ready to pull the trigger on an RCD330 from China with android auto and Skoda's green backlighting, but I just wanted to make sure it will work with my car's DSP -
I have read on some forums that people have managed to get it working with VW's Dynaudio / Fender sound systems by disconnecting and re-connecting the battery - will this trick also work for my car? My hope is that since the RCD330 works with the VW sound systems, it can work with skoda's as well?
Here are the current coding values I have applied to my Columbus to get it working with the DSP
BYTE 1: 02 Skoda Sound System (CAN DSP)
BYTE 2: 00 Sound System (active speakers)
BYTE 4: 01 Speaker Monitoring: Inactive (Sound System)
BYTE 5: 01 Equalization: Seat Altea (5P) / Skoda Octavia (1Z)
My concern is BYTE 1:
the skoda sound system is marked as CAN DSP, while the VW/Dynaudio/Fender sound-systems are marked as BAP DSP - dunno what this entails
Your inputs are greatly appreciated
Here is an autoscan of my car if it is of help :
Sunday,17,December,2017,17:28:50:39616
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: TMBBSD1Z66A1xxxxx   License Plate: SKODA OCTAVIA II
Mileage: 121440km-75459mi   Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 37 42 44 46 47 52 55 56
          62 72
VIN: TMBBSD1Z66A1xxxxx   Mileage: 121440km-75459miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 LB    HW: 03G 906 021 LB
   Component: R4 1,9L EDC G000AG  8501
   Revision: --H03---    Serial number: SKZ7Z0F3525774
   Coding: 0000078
   Shop #: WSC 73430 790 00000
   VCID: 6AD1FCF345E5291634-803E
1 Fault Found:
001025 - EGR System
               P0401 - 000 - Insufficient Flow
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 119559 km
                    Time Indication: 0
                    Date: 2017.11.08
                    Time: 13:44:52
             Freeze Frame:
                    RPM: 1386 /min
                    Speed: 27.0 km/h
                    Load: 18.8 %
                    Duty Cycle: 14.6 %
                    Duty Cycle: 100.2 %
                    Mass Air / Rev.: 260.0 mg/str
                    Mass Air / Rev.: 510.0 mg/str
Readiness: 1 1 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 043     HW: 02E 927 770 AE
   Component: GSG DSG         070 1106
   Revision: 04507000    Serial number: 00000602020352
   Coding: 0000020
   VCID: 51A34B1FC873FACE55-8004
No fault code found.
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BL    HW: 1K0 907 379 BL
   Component: ESP MK60EC1   H31 0152
   Revision: 00H31001
   Coding: 113B201C092700FA881204EB901A00A1300000
   Shop #: WSC 00066 123 12345
   VCID: 7DFBC7AFE46BAEAEE1-8028
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 J
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3D7B07AF64EB6EAEA1-8068
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
            000 -  -
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 06180AB8F80100C000080080000091AC03E000AE632085005C0020000000
   Shop #: WSC 73430 790 00084
   VCID: 387516BB8BC94B8672-806C
   Subsystem 1 - Part No SW: 1Z2 955 119 A    HW: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  12  0401
   Coding: 00FFF5
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSen  11  1110
   Coding: 073025
7 Faults Found:
01504 - Bulb for License-Plate Light (X)
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 2
                    Fault Frequency: 44
                    Reset counter: 158
                    Mileage: 119521 km
                    Time Indication: 0
                    Date: 2017.11.04
                    Time: 11:28:13
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.25 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 140
                    Mileage: 119521 km
                    Time Indication: 0
                    Date: 2017.11.04
                    Time: 11:30:06
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.30 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00080 - Function Request - Sliding Roof
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 140
                    Mileage: 119521 km
                    Time Indication: 0
                    Date: 2017.11.04
                    Time: 11:36:33
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.20 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01800 - Light Switch (E1)
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 29
                    Reset counter: 158
                    Mileage: 119540 km
                    Time Indication: 0
                    Date: 2017.11.06
                    Time: 18:01:19
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.85 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00897 - Windshield Washer Pump (V5)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 150
                    Mileage: 119902 km
                    Time Indication: 0
                    Date: 2017.11.18
                    Time: 18:21:44
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.95 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 6
                    Reset counter: 158
                    Mileage: 120192 km
                    Time Indication: 0
                    Date: 2017.12.06
                    Time: 21:02:25
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 120885 km
                    Time Indication: 0
                    Date: 2017.12.13
                    Time: 06:14:44
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.80 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 56D 919 475 A    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0006
   Revision: --------    Serial number: 35821322300343
   Coding: 300101
   Shop #: WSC 68203 123 12345
   ASAM Dataset: EV_EPHVA18VW4110000 001007
   ROD: EV_EPHVA18VW4110000.rod
   VCID: 336F21979AAFA8DE47-8066
1 Fault Found:
12658720 - Databus
          U1121 00 [009] - Missing Message
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 140
                    Mileage: 119521 km
                    Date: 2017.11.04
                    Time: 11:28:11
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 S    HW: 1K0 909 605 S
   Component: Q3 AIRBAG VW8   026 0800
   Revision: 09026000    Serial number: 0038ND0VR70Q
   Coding: 0020787
   VCID: 3C7D0AAB7FF167A696-8068
   Subsystem 1 - Serial number: 6332MSME0E0C5E04K
   Subsystem 2 - Serial number: 6342MSME0D42032FB
   Subsystem 3 - Serial number: 6351HSME092D0A0CD
   Subsystem 4 - Serial number: 6361HSME0929003C3
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           034 0070
   Coding: 0012042
   VCID: 77F7D587065784FEBB-8022
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           007 0050
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 843 D    HW: 1Z0 920 943 G
   Component: KOMBI         H05 0112
   Serial number: 00000000000000
   Coding: 110F00
   Shop #: WSC 73430 031 00999
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
   VCID: 397313BFB8C3528E8D-806C
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 061213F2000953
   Coding: 351303
   VCID: 7CFDCAABFF71A7A6D6-8028
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H05 0112
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 B    HW: 3C0 959 760 B
   Component: Sitzverstellung     0701
   Revision: 00003000    Serial number: 00000000000000
   VCID: 2C5D3AEB8F91F72606-8078
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 3T0 035 680 G    HW: 3T0 035 680 A
   Component: RNS-MID       H42 5238
   Revision: AB001001    Serial number: SKZ6Z7L9014015
   Coding: 08020040010100A00000
   Shop #: WSC 33361 790 00999
   VCID: 346D228B97A1AFE65E-8060
3 Faults Found:
00856 - Radio Antenna
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 222
                    Reset counter: 158
                    Mileage: 119520 km
                    Time Indication: 0
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 130
                    Reset counter: 158
                    Mileage: 119520 km
                    Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 195
                    Reset counter: 158
                    Mileage: 119521 km
                    Time Indication: 0
                    Date: 2017.11.04
                    Time: 11:28:20
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1T0 959 701 C
   Component: Tuer-SG         024 2438
   Coding: 0001014
   VCID: 3777158746D744FE7B-8062
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V2.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.2   D06 1701
   VCID: 346D228B57A1AFE65E-8060
Address 47: Sound System        Labels: 1Z0-035-456.lbl
   Part No SW: 1Z0 035 456     HW: 532 226 800
   Component: SK35-DSP        4   1000
   Revision:   4         Serial number: 00012413
   Coding: 0000000001
   VCID: 72E1E4936D35E1D68C-8026
2 Faults Found:
00872 - Bass Speaker Rear Left (R15)
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 20
                    Reset counter: 255
                    Time Indication: 0
00420 - Front Right DSP Midrange Speaker (R104)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1T0 959 702 C
   Coding: 0001022
   VCID: 387516BB4BC94B8672-806C
Address 55: Headlight Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000007
   VCID: 74EDE28B1721EFE69E-8020
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
3 Faults Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 158
                    Mileage: 119520 km
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 158
                    Mileage: 119520 km
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 158
                    Mileage: 119521 km
                    Time Indication: 0
                    Date: 2017.11.04
                    Time: 11:28:20
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2435
   Coding: 0000144
   VCID: 32612493ADB5A1D64C-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 E
   Coding: 0000144
   VCID: 336F219752AFA8DE47-8066
End-------------------------(Elapsed Time: 02:41)--------------------------
  • 4 months later...
update to this thread:
I bought an RCD330 (skoda version) from the interwebs and installed it to my car. The sound system does not work with it - this unit does not accept the coding to enable the sound system. So anyone planning to install this to an Octy II / Superb with sound system, I'm afraid this wont work.
The sound systems of the Superb II / facelift Octy II can be made to work with a trick - Read Here , but the it does not sound as good as a columbus / bolero that came along with the car
I sold my unit and have gone back to the Columbus.
Too late to check now, but most RCD330 users claim they can set the output to "Skoda Sound System (CAN DSP)" which I'd expect to work in a pre-FL (DDP car).
However, it won't accept changing the EQ to anything but linear.
