service reminder
the fabia was serviced in may 2017 but i dont think, being a filling station type service bay they set the service reminder
up until today it was just reminding me...now it rings and a little spanner is on the speedo readout dial
i understand that one can cancel this some way or other..that would be a help
cheers
geof
14 hours ago, Wonky said:
There have been a few posts over the years, a quick forum search found this one but there are others.
https://www.briskoda.net/forums/topic/389196-service-interval-display-reset-that-works/?tab=comments#comment-4535381
can you let me know where the RH 0-0 button is please
is it the trip button as the other is the clock
i know its a silly question....dohh
cheers
Geof
Edited by mrcrow
We have an 09 Fabia and it appears that I cannot do a reset via the trip button - I believe that on some cars you can and some cars you can't - hopefully you will be able to on yours mrcrow.
I will presumably have to talk to a friendly vcds owner to get mine reset LOL
Yes, any fabia you can reset the service reminder.
Note it is only possible if the service indicator (spanner) is showing and it will reset to fixed service intervals (9400 miles/372 days).
For cars with the  page and 0.0 buttons
1 With ignition OFF
2 Press and hold RH 0.0  button
3 After 5 seconds, turn on ignition, still pressing 0.0 button
4 After another 5 seconds, release 0.0 button and press LH button and hold for 5 seconds
5  Release button and turn off ignition.
Earlier models with the one trip button
1 With ignition OFF
2 Press and hold trip button
3 After 5 seconds, turn on ignition, still pressing trip button
4 After another 5 seconds, release trip button and  twist the button to the right and hold for 5 seconds
For cars with maxidot
Navigate to the status/settings menu and use the service reset option. Note, you will have to have the doors closed and ignition on to access this menu.
Afaik except with maxidot, it is not possible to reset the service indicator unless the spanner is showing that a service due soon/now.
Resetting the service interval will put the computer into fixed service interval mode (372 days / 15000km) or approx 9400 miles. The spanner comes on 1500km (about 900 miles) before the service due now messages start.
1 With ignition OFF
1 With ignition OFF
1 With ignition OFF
brilliant input !!
thanks a lot...without that i would be messing about on my single trip knob 2008 fabia
top marks from me
cheers
geof
Edited by mrcrow
yes...by now you may have seen the post above which i quoted
will have a go and report back...mine is a dec 58 but still its a 2008 single button
if you try it yourself it would be good to know if it also works on your specific 2009
ps is that perth in "there's no place on earth than the homeland of my birth"...andy stewart when sober..:cool:
used to go there if it was a lot as i was in the black watch territorial military band
and walks along the river of course
cheers
geof
? Andy Stewart - where is he now, well I suppose we know the answer to that!  Sides of the river now suitably protected from the river water escaping onto the streets I think, I suppose that area is my ancestral home, but not where I live! Used to have lots of "good" shops, globalisation sorted that situation out, well we need to blame something nasty!
Aye, Andy is in his but and Ben somewhere....with a bottle of the electric soup
i used to watch the white heather club on Hogmanay....
cheers
geof
Hi xman - I thought I had tried all the usual methods to reset our service indicator but I will retry when the weather improves a little LOL
I had read somewhere that some Fabias could not be reset using the trip button method - I have reset previous VW group cars ok !
cheers YS
cheers
geof
It is that same Perth Geof  :)
Gawd Andy Stewart LOL - our local muso when I was a kid was the late great Jimmy Shand ;)
My GF's dad was a Black Watch man !
In a previous life I had the pleasure of marching up and down the hill behind a pipe band whilst an RAF apprentice.
cheers YS
cheers YS
yes jimmy shand
i used to hang out at fort william when i was a biker 1961-65...and never forgot to take my cromach just in case we would tak the road to the isles and the far cuillins
what apprenticeship did you do in the RAF...i did marine engineering in the shipyards...repairs and new work but i did don RAF uniform when i served in the ROC 1964-190 at turnhouse and underground post C1 bo'ness...
spotting was still done then as exams...flash silhouettes
cheers
geof
Hi Geof
I did A Fitt A training as an apprentice (aircraft fitter airframes) - later changed to A Tech A (technician)
Followed by 45 years as an a/c technician - after I left the RAF in 1983 I became dual trade Airframe/Engines but I never had any formal training with engines,as I said on the career thread my mis spent youth messing around on motorbikes and cars helped me no end LOL.
LOL I did flash silhouettes as an air cadet in our recognition team.
Nice part of the world you live in :)
1 With ignition OFF
I have just tried it again and following the instructions to the letter - no reset and now will have to readjust clock again as the clock time moves as soon as I twist the button c/w.
rgds YS
Firstly it will only work if the service spanner is showing
Secondly, you may need to be sitting in the car with the doors shut
Extend those times to 10 seconds.
Remember to keep the trip button pressed in throughout.
Final step maybe its twist the trip button while its being held in.
It took 3 or 4 attempts before mine reset. (Single trip button 09 htp)
i think that could be the key
if the trip button is in to change trip reading..."circuit"...could be it also zero's the service mileage
(you would think i knew this all a long...clever clogs me)..:blink:
glad someone was brave enough to try it...i will give it a go as well...i have another clock in the car
https://ssli.ebayimg.com/images/g/FKgAAOSwgmtaQhWv/s-l1600.jpg
mrs crow cant see the on on the dash so i put it on her side of the binnacle..slightly pointing to me as well
it isnt digital so my brain takes it in easier
cheers
geof
Edited by mrcrow
It only takes a minute to reset the clock to the correct time.
Thanks for reply xman
Spanner is showing
I was sitting in with doors shut
I did try it @ 10secs but after further googling I might try it out to 15secs
I have tried it a few times and agree it could be technique partly,but I have reset other vw group cars successfully (our other car is an 02 Polo and I have previously reset Golfs and  a SEAT).
I did see somewhere on the web that some fabias cannot be reset using the button - but I got sidetracked this arvo and could not get back to either the web or the car.
rgds YS
absolutely...and with one of my disconnect the battery issues i have gotten used to setting it...it isnt as hard as the one on my 51 1,6 golf S 16v
the button would go to the side and then nothing happened...then a burst of number changing..
cheers
geof
