headlamp
hi just joined I have a small problem with the auto leveling
headlamps
on my 2007 Octavia vrs the beam seems low is there a way I can adjust the height manually or does it have to be done with a computer, and the car doesn't have an adjust button by the
steering
wheel
regards
sean
Xenon/Halogen bulbs?
They have little drop links attached to the front and rear suspension which are connected to sensors. Once one of the ball joints seize, it will snap the sensor lever....
Edited by Lyminton
hi they are xenon
Hi,
Look under posts for "rear suspension level sender" Had some great help from the forum !!
I had a similar problem a few months ago, after a service by an independant, was informed that the rear suspension level sender drop arm had broken (£200 to replace - this probably included the sender itself !)
Didn't know what it was or where - see posts to find out. Having found it I made up a new drop arm, cost around £8 still working (so far !)
The front sensor is similar, on the nearside ? front suspension (mine was OK).
Regards,
Lloyd
