Which pad ?
Hey all. I asked John from forensic detailing this same question a few weeks ago but no reply as yet. Here goes;
When using megs 105 to remove wetsanding marks ie; off 3000 paper. I am currently using the orange hexlogix pad. Would any one recommend stepping up to the yellow hexlogic pad to make the process easier, or changing things completely to a microfiber pad. that's it really. Thoughts anyone.
Microfiber would be a good choice here tbh, if you've got the options then just try them and see what works best
Use caution on the yellow pad
With megs #105 and yellow that's a pretty aggressive combo
Is the orange not removing it ???
722
Edited by malcster
Thanks for the replies guys. The orange pad does eventually remove it, but I've been caught out in the past on one of my neighbours cars. I'd corrected the full car as best I could( in the luxury of my dads double garage) All looked absolutely spot on till the next morning when it was sat back on my neighbours drive with the sun beating down on it. I had to re do about 8 patches where I'd been wet sanding. The car is pearlescent black by the way. This is why I'm keen to step up the aggressiveness of pad choice. just don't know which one to buy.
Megs microfiber pads are always recommended. Personally i've not used them but i have used CarPro ones that i thought were awesome
I’ve been here too and simply preserved with the orange pad. Came round once I found the sweet spot for working time.
I assume you’re going back over with 205 after the 105?
Yep, 105 then 205. Think I'll purchase a microfiber pad, maybe look at the megauirs ones like RobLarby suggests. When you've got a lot of wet sanding marks to remove I'm thinking these microfiber pads could be a game changer. One more thing before I buy one. Are they ok to use with the D.A set up ?
From what I’ve read they get good reviews and works great apparently, but not felt the need to move over myself.
I've been swatting up on you tube. There's some good videos on there about the m/f pads. As Rob mentioned, the megs looks highly rated. Comes in a twin pack too which is good, as it is recommended that they are cleaned out periodically with compressed air which I don't always have. Definitely going to purchase a pack of these.
I have never.used the megs microfiber pads is the range coded to job requirements
Ie one for cutting
One for polishing and a finishing one ??
Ie one for cutting
From what I understand, there is a cutting pad and a polishing pad. I shall just be buying just the cutting pad and then moving back over to the desired hexlogic foam pads to finish.
Hmm ill look into these
Currently using hexlogic quantum pads but like trying new things
Yeah, definitely worth a shot. If it makes my life easier its a no brainer. I've just looked at the pad selection again and its available in "cutting" and "finishing" and usually come in a twin pack which is good.
Do these fit a 5.5 das pro
Can find 5 and 6 inch or am I being stupid
I've noticed also that they only come in 5 & 6". I'm guessing the 5" pad will be suited to the 5" backing plate. A 6" pad would surely have way to much over hang on a 5" backing plate.
Got a response
Hi Malcolm,
Yes those are correct. Listing pads is hard as the face is always different to the backing. But the backing is the most important part.
So yes even though they are 5.5” they are to fit a 5” plate which you have with the DAS, so those are the ones you need. They are good as well and ado work really well on the DAS 6.
Many thanks
Tim
Well that clears that up then. Shall be ordering mine soon. Thanks for sharing Malcolm.
