VCDS Tweaks for O3FL VRS
On 23/01/2018 at 22:01, wg100 said:
This is what it should look like:
On 24/01/2018 at 00:14, YMe said:
A shot in the dark here but would you not have to tick Bit 0 as well? Especially if none of the items in the list are currently activated.
I coded a 2014 SE (so no MFSW) pre FL O3 today and Bit 0 was left unticked whilst I ticked Bit 4, this then worked perfectly by showing the amount needed to fill the tank.
  • Replies 60
  • Views 14.8k
  • Hi Legend, Can confirm that the coding will work on the FL03 for HBA, TCR(speed limits), Convieneance turn, Lap timer, Comfort seat(electric) on engine off and LED’s on fan speed in Auto.  Unable
  • Well guys sorry for the late reply but at last thanks to all the help from this post I gave eventually coded the twin rest fog lights and got the refill Turk quantity working. The later after a reset
  • And when you come to sell it you'll get most of your money back.    Genuine VCDS cables always hold their money well.
On 23/01/2018 at 19:53, wg100 said:
I can confirm that the latest Beta shows the longcoding now. I've been able to perform the long coding adapatations that previously weren't possible. I too had the issue of binary only when I first got my car in Sept.
I’ve been trying to code HBA using VCDS Ver: 18.1.0 and Hex-Can USB cable.
Whilst I can select / change adaptations, the long coding for 09 Cent Elect module 5Q0 937 084 CQ is stating “Coding is not supported by this control module variant”.
Anyone able to code this module with the same interface?
Ah, that's your problem. You can't code some of the MQB2 modules with that dongle. You need a Hex-V2 or Hex-Net to be able to do so. Maybe time to upgrade...
Edited by wg100
I couldn’t do 09 longcoding on my HEX-NET either (17.8.1)
Edited by Gizmo
Thanks for the quick response. Perhaps when I upgrade my own fleet; my mates with flash cars can whistle for a while!!!
Cheers.
Can you confirm 09 Cent Elect Pt No for your vehicle?
Just had a look at one of my autoscans. My Module 09 is 5Q0 937 084 CG vs CQ for yours. That may also play a part. Have you sought any advice from Ross-Tech?
How many VIN's can you do with your lead ?
Oh yeah, leading question....
I think I got a 10 VIN, so some beer tokens wouldn’t go amiss towards an unlimited cable!
Your on, tell me when you've got the performance setting for the E-diff sorted as I NEED that too
@Black_Sheep I have managed to code HBA on my FL03 with Hex-V2 cable and the09 Cent Elec module is 5QO-937-086-BM. Which is on from both yours and wg100. Guess you need someone close by to try the V2 cable before purchasing.
Edited by RoboOp
