Reverse camera Amundson+
Hi does anyone know if a reverse camera will work with the Amundson + head unit ??
yes
proper VW RGB camera will plug into the slot at the back
Or you can fit a kufatec media module then any camera with a video signal will work
.....and works very well too! ;)
Choice of cameras can be a little limited: you can get ones that replace one of the number-plate lights, or replace the tailgate release handle (just end up with a narrower handle), or number-plate surround ones. Depending on your luck, you may need to relay a clean power feed, as running one straight from the reverse ligh can be dirty and mess the picture up.
I had one on my estate and managed to get it so you could just see the tow-ball in the screen ;)
