Window regulator
My daughter's f/n window went o strike today, so I had the pleasure of stripping out the door and fault finding. In a nutshell the cable unwound itself from the drum and new regulator mechanism is on order. So as to refit the panel and regulator into the door, does anyone know the size of pop rivet I need? Ta.
Edited by Guest
Door carrier rivets are 6.4x10mm. Part number N91078801
Window regulator to carrier are 4.8x15mm. Part number N90765701
You will need a lazy tong riveter to install the carrier rivets as they are bigger than most standard pop rivet guns can handle.
Edited by TMB
Ordered a regulator ready fitted to the carrier. Transfer her speaker and such across, job done, hopefully. Thanks Lee
No probs.
Speaker rivets are the same as the window regulator ones.
:thumbup:
