DTUK® CRD-T+® DUAL CHANNEL
I have a question about this. When you turn the box on (press simultaneously + and - for couple seconds) then you can adjust program go up or down. If you keep going in one direction (for example pressing just -) at one point all the lights turn off. Is this the state when the box is without any program like its not installed?
no, it comes with a blanking plug to run it at stock. i have no idea why all your lights are going out, message DTUKs  Andrew directly his username is andrew@DTUK
That’s not quite right - you can turn he box off to run standard while it’s still connected. As you cycle up through the programs, 1, 2, 3 and then the next step will be off before it reverts back to 1.
3+ is totally different then.,
that must be it, but the problem is that in off still feels like its on?
