Rear left door problem-window doesn't work & door doesn't lock
Hi,
I have skoda yeti 2012 and I have a  problem in my rear left door (behind the driver): the window doesn't work and the door doesn't lock, the window doesn't open also from the driver switch.
Is there a relation between the window and the door? What is the problem and can it be fixed?
Get it scanned with vcds.
At a guess, the will be a writing fault in the loom to the door. You might be able to pull back the rubber gator between the door and car body to take a look.
