Extendad Manifacturer's Warranty from Skoda
Hi all! My standard 3 years warranty is about to expire at the end of this month and I am at dilemma if I should purchase extended warranty from Skoda direct  (as seen on their web-site LINK)
There are 2 options: Named part & All parts Cover, but it isn't very clear which parts are excluded and which scenarios would not result damaged/faulty part to be fixes free of charge. Also does general wear & tear would be covered, for example clutch/flywheel or turbo?
 I could not find much relevant information in the search, so I would like to ask other Superb Mk.2 owners to share views and experience. Cheers!
Just to answer partly my own question - Quote from the warranty booklet:
We
will not pay for:
Airbags, batteries, non-Xenon and non-LED bulbs, exhaust
systems, water ingress (including damage to covered parts
caused by water), wiper blades, wheel balancing and alignment;
wiring, wiring looms, connections and fuses, wheels and tyres.
Any losses or damage to components that are not directly
covered within the terms of this warranty.
All bodywork components including encased aerials, paintwork,
glass, seals, sunroof assemblies, soft top roofs, and any
component, which may require adjustment from time to time.
Body panels.
Catalytic converters and diesel particulate filters.
Diagnostic time of any type (unless incurred as part of a
valid claim).
Routine servicing (all components replaced associated with
routine servicing are excluded).
All adjustments, cam belt timing, diesel pump timing or cleaning.
Components that are not of a matching quality to ŠKODA
approved components
Seat frames.
Gas struts.
Strikers and hinges.
Brake frictional material
Clutch frictional material
Constant Velocity (CV) boot gaiters.
External oil leaks (unless it requires the removal of a major
component e.g. Engine, Gearbox, Rear Axle), lubricants, filter
elements and any damage caused by frost or lack of anti-freeze,
impact, accident or negligence.
Electrical software update or reprogramming unless required due
to the failure of a covered part.
Interior trim including seats, seat belts and pre-tensioners.
Normal maintenance services, and the replacement of such
items as, but not limited to, spark plugs, plug leads, oils, filters
and lubricants (the cambelt is covered providing it has been
maintained correctly).
Recharging of the air conditioning unit, owing to natural depletion
of the refrigerant.
Renewal of any clutch components due to
wear and tear
misuse
or incorrect adjustment.
Renewal of brake components due to
wear and tear
or constant
use of the brakes.
The clearing of fuel lines, filters, fuel injection system, throttle
body, pumps and any damage caused by contaminated or
incorrect fuel.
The gradual reduction in operating performance (
wear and tear
due to the age and mileage of the covered vehicle.
Traffic management system, telephone including Bluetooth, TV/
DVD, satellite navigation system and associated equipment of all
types.
We
will not pay for fixed or portable in car entertainment systems
including, but not limited to, audio or video equipment, games
consoles, CD multi-changers, MP3 or
iPod equipment, speakers, amplifiers, remote controls.
Any exclusion detailed under the General Exclusions sec
types.
And this considered almost defies the subject of having extended warranty! :-(
I've extended mine for the second time and they offer you a discount for the second year. I've gone for all parts cover but wear & tear is NOT covered for clutch/brakes etc - Turbo should be covered though. I thought it was fairly cheap but mine is only the 1.4tsi which I think makes it cheaper.
Thus far I've not needed the original 3 yr or extended warranty for anything at all (now 55k miles) , hope it stays that way :sweat:
Edited by bigjohn
The exclusion also said infotainment system when I was offered it.
Looking at the most likely things to fail and seeing that they were all excluded I quickly realised just what a scam the extended warranty was.
Apart from the fact I wouldn't want my local dealer anywhere near my car.
