Hid
For those of you interested in the HID conversion check out the following at vagparts.com:
H7 xenon retro fit kit
Complete H7 retro fit HID xenon kit. Kit includes 5,600K xenon bulbs, starter ballasts, ballast brackets, leads and fittings. Simple to fit (average fitting time 1 hour), no cutting of wiring looms! Perfect for plastic lens headlamps or glass! You can revert back to standard lights with ease when you sell your car and take the kit with you! Please check that you have two flat surfaces too mount the ballast brackets to. Each ballast measures only 9.2cm long, 7.8cm wide and 2.9cm high. HID xenon bulbs use half the power of halogen bulbs, but produce 2-3 times the light output!. Kit price now reduced by
what about the automatic levelers that go up and down with suspension and headlamp washers (which both are a legality)
