Maxidot stuck on phone
Can any ody help
upgrded to dab columbus, no issues and all working fine but the maxidot defaults ro the phone settings screen everytime. I can naviagte the phone settings with the steering wheel buttons but I can’t exit to the other options (MFD, audio etc)
if i set a new naviagtion destination on the columbus I can quickly choose MFD or audio on the maxidot but if the phone rings it gets stuck again
i have reset the columbus, disconnected the bluetooth module overnight but nothing works
columbus is running V15 maps and 5238 SW
driving me mad so any help appreciated
Two possibilities:
1. BT module set in coding to VW or SEAT instead of Skoda
2. Gateway set in coding to VW or SEAT instead of Skoda
Thanks for the tips, I have VCDS so I can look but, which section of VCDS are the BT Module and Gateway found so I can check?
if you can help, and it sorts it, I will owe you a beer if you ever come to Basingstoke in the UK!!!
well I fiddled to find these settings and it's back to working properly
thanks for the advice
Great!!!
  • 4 years later...
Hi Massline, do you have any recollection of what you changed to make it work? I'm having the a very similar issue with my 2009 fabia which I've upgraded to an RCD510. I can't use my mfd at all and steering wheel congrols don't seem to work either. I have a feeling it could be CAN, but no tangible evidence to support it.. Cheers!
