Dash Cluster Pin Location ?
Hi all, I am trying to locate Pin no. 9 on a 2012 F/L Octy Dash connection.
It has the Blue 32 pin connector (and no other connectors at all going to the cluster).
There aren't any markings on the plug and I just need to know which is pin 1 and pin 32 (or similar) to enable me to locate pin 9.
It's for a speed pulse wire on a Taximeter BTW.
I have searched the Forum, but while the pin no. info is mentioned there is no mention of the plug layout.
Thanks in advance.
They should be numbered.
You might need to slide the black internal connection block out of the blue plastic to see the numbers.
Spot on langers2k. Meter fitted and working perfectly. Thanks for the quick reply.
