Wheel centre caps
What is the easiest way to remove the center cap from my Monte alloys?
I am going to apply  Bilt Hamber autowheels to clean them and the instructions warn to avoid any plastic trim.
Ta
Andy
Take the wheel off and push out from the back of the wheel.
Trying to lever them out from the front only ends in tears.
Thanks AG Falco
Thought so.
Unless you add a hot glue stick to it, let it dry, pull gently and warm stick to remove and clean off residue. By the time you have done this though, removal of wheel might seem better. If you are doing a full clean, you'll most likely want them free of the car.
