poor starting & other issues
Hi All,
I have a 2009 1.4 TSI auto.
I have been having problems especially in the colder weather.
When I go to start the car it will not hold the revs and will cut out, if I hold my foot lightly on the accelerator pedal when starting it will then keep running. in the warmer weather sometimes it manages to hold the revs and not cut out, however once initially started it will be fine throughout the day.
A scan came up with nothing in relation to the starting issue, however it did show the following codes; does anyone have any ideas on these or possible solutions?
18047/P1639/005689 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
17887/ P1479/005241 - Brake Boost Vacuum System: Mechanical Failure
Thanks.
I did some research and I think there is a newer software version for this ECU (SW:9970) but I'm not sure if that would help. It might be worth checking erwin to see if it's mention in a TSB/TPI against your VIN and what issues it addresses.
Anyway, below is a full autoscan if others have any ideas.
Tuesday,08,May,2018,08:40:41:30291
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: TMBBJ21Z292------   License Plate:
Mileage: 128940km-80119mi   Repair Order:
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBJ21Z292------   Mileage: 128940km-80119miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 906 016 E    HW: 03C 906 016 C
   Component: MED17.5.5       G   3597
   Revision: L3H04---    Serial number:
   Coding: 0000077
   Shop #: WSC 73430 790 00000
   VCID: 211F1B44ADCE8F3F5D6-8074
2 Faults Found:
008504 - Accelerator Position Sensors (G79) / (G185)
               P2138 - 000 - Implausible Correlation - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2047.15.31
                    Time: 31:63:63
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 87.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.938 V
               P1479 - 000 - Mechanical Failure
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 128918 km
                    Time Indication: 0
                    Date: 2012.09.28
                    Time: 07:51:53
             Freeze Frame:
                    RPM: 954 /min
                    Load: 37.2 %
                    Speed: 0.0 km/h
                    Temperature: 38.0°C
                    Temperature: 15.0°C
                    Voltage: 14.097 V
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 048 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     402 9059
   Revision: 00040024    Serial number: TFK00901291506
   Coding: 0000020
   Shop #: WSC 50413 001 1048576
   VCID: 392FD324255EF7FF756-806C
1 Fault Found:
006012 - Clutch 2
               P177C - 003 - Tolerance Limit Reached - Intermittent
             Freeze Frame:
                    Fault Status: 00100011
                    Fault Priority: 0
                    Fault Frequency: 254
                    Reset counter: 10
                    Mileage: 108665 km
                    Time Indication: 0
                    Date: 2012.03.28
                    Time: 14:03:16
Address 03: ABS Brakes (-----)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 133B201C092600FAC80B04ED901D0080A900
   VCID: 75B71F1445C6539F51E-8020
No fault code found.
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 AB    HW: 3T0 907 044 AB
   Component: Climatronic   122 0203
   Revision: 00003001
   Coding: 0100000000
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 72BD2408342844A774C-8026
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087     HW: 1K0 937 087
   Component: BCM PQ35  H   020 0358
   Revision: 00020000
   Coding: 40180AB89053B1C04010008011008164017800AE626D89605C0440000000
   VCID: 6E85307820906047904-803A
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 11120  22  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 120209 05  54  0402
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
6 Faults Found:
00896 - Trunk Lock Unit (F256)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 4
                    Fault Frequency: 116
                    Reset counter: 64
                    Mileage: 110732 km
                    Time Indication: 0
                    Date: 2012.04.12
                    Time: 15:54:32
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.85 V
                        OFF
                        OFF
                        Term 50 Off
                        OFF
                        OFF
02382 - Sensor for Light Detection (G399)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 128779 km
                    Time Indication: 0
                    Date: 2012.09.25
                    Time: 11:33:60
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.90 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
02394 - Parking Light Left Front (M1)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Reset counter: 26
                    Mileage: 117604 km
                    Time Indication: 0
                    Date: 2012.06.14
                    Time: 15:58:48
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.70 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
02395 - Parking Light Front Right (M3)
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 26
                    Mileage: 118259 km
                    Time Indication: 0
                    Date: 2012.06.21
                    Time: 13:27:12
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.70 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 145
                    Mileage: 121085 km
                    Time Indication: 0
                    Date: 2012.07.22
                    Time: 08:41:54
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.70 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 119
                    Reset counter: 65
                    Mileage: 121086 km
                    Time Indication: 0
                    Date: 2012.07.22
                    Time: 08:54:34
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.50 V
                        ON
                        ON
                        Term 50 On
                        OFF
                        ON
Address 10: Park/Steer Assist (J446)       Labels:. 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475     HW: 1Z0 919 475
   Component: PARKHILFE 4K  H06 0004
   Revision: --------    Serial number: 66640904804518
   Coding: 000101
   VCID: 7EA5003870F010C7004-802A
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2B6ETP
   Coding: 0020788
   VCID: 3D27C7343176CBDF59E-8068
   Subsystem 1 - Serial number: 6332MSME442636646
   Subsystem 2 - Serial number: 6342MSME44247005+
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001034
   VCID: 025D74C80808742764C-8056
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 1Z0 920 903 B    HW: 1Z0 920 903 B
   Component: KOMBI         H20 0107
   Serial number: 00000000000000
   Coding: 410F00
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 3431E2100EBC0A97A60-8060
Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K092030A7E
   Coding: EDA07F06000202001303
   VCID: 372BD51C134AE18F832-8062
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H20 0107
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
   ROD: EV_Immo_UDS_VDD_RM09.rod
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
   Part No SW: 1T0 959 701 N    HW: 1T0 959 701 N
   Component: Tuer-SG         008 2012
   Coding: 0004854
   VCID: 42DDB4C84888B42724C-8016
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 68     2501
   Revision: 00H15000
   VCID: 2C01FA70DA0C5257FE0-8078
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 1T0 959 702 N    HW: 1T0 959 702 N
   Coding: 0004854
   VCID: 43D3B1CC5792BD2F2FA-8016
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         534 Y802
   Revision: --------    Serial number: VWZZZ4R6209226
   Coding: 16000400040005
   Shop #: WSC 00078 790 00208
   VCID: 46D5A8D868A08807084-8012
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00110100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 106
                    Mileage: 118259 km
                    Time Indication: 0
                    Date: 2012.06.21
                    Time: 18:02:24
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 AK    HW: 1K0 959 703 AK
   Component: Tuer-SG         007 2001
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 79AF132465DE37FF356-802C
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 AK    HW: 1K0 959 704 AK
   Coding: 0000144
   VCID: 7AAD0C2860D83CE73CC-802E
End----------(Elapsed Time: 01:08, VBatt start/end: 12.1V/12.2V)-----------
