Possible Timing chain failure - options
I have a 2011 VRS TSi with a suspected timing chain failure (at least according to the recovery driver).
From cold start, there was a rattling noise and nothing else...
Symptoms:
Seems to crank faster then normal
Appears to be zero compression
Oil on spark plugs
The only error code is P2294 - Fuel Pressure Regulator 2 open
Assuming this is a chain failure (and therefore not good news...) what would be the best options?
Recon engine fitted by generic supplier
Engine rebuild by specialist independent VAG
Give up and get another car...
For background, the car has covered 70,000 miles and it otherwise on good condition.  No documented service history, so probably no point in discussing with Skoda...
Any advice welcome!
i would defo say it's chain failure,the fact there is no compression points to that.the best option is to have the cylinder head rebuilt by a VAG specialist(hopefully it's just the head thats damaged) and have the latest revision of chain and tensioner fitted.
I'm booked in at my local specialist next week for a diagnosis.
Any idea what the potential costs might be - worst / best case?
