Adding a USB
Does anyone know if it's possible to add a USB to the box between the two front seats? Need two so I can charge the phone I use for music and personal stuff and another for the work phone.
Putting another socket in the box makes gives a neater solution. I noticed a blanking plate at the back so assume something fits in there.
My car is a 2018 MY and has the Amundsen system if it makes a difference
Thanks in advance.
Edited by sf73Rutland
I decided for just a 12v socket with dual usb ports.. Thisnthen gives 3 usb ports in total for £2.50
Anyone any ideas with this? Want to fit either an additional USB or 12volt socket into the cubby box between the seats so it's neat and tidy. Ta.
The easiest way is to tap into the fuse box into a non perm live which is behind the glove box.
Run a feed above the football carpet and then under the centre console arm rest...
Remove the screws in the base of the armrest to allow you to raise it for when you install the cable.
You could try to feed the wire via the light hole (maybe removing it ) or drill the base to wire entry.
