Rear washer jet on when using front windscreen washer jets
As per title, a little strange.
The rear washer jet comes on when using the front washer jets, rear works as should when using on its own
Any thoughts
Are the front jets good and clear? Wondering if there is pressure building up.
Had a funny thing like that happen once.... Might have been a blown fuse but to be honest, I forgot about it till now. Try looking at all relevant fuses though. Proper checks, swap/replace if necessary. Also, check bonnet is shut properly although I think that was a different outcome.
Yeah both work strong and well when using but just rear squirts with the fronts
Will check fuse(s)
