OBDeleven coding
Has anyone used OBDeleven to change MDF to show MPH, enable Teardrop Wipe, Rear Lights
to be on when ignition on (rear DRL's) or any other coding mods?
Ive done the MPH mod with OBDeleven on my 09 Superb - its pretty straightforward. Can I help?
oodoom, yes please, someone else has helped me with the Speedo Staging which was easy (When you know how)
I'll plug my dongle in tomorrow if I get chance, need to refresh my memory before I go giving you advice!
This should help for starters (think you go into long coding in the Gateway module to find the country setting)
How do I display the large MPH display on my maxidot?
(needs the latest white maxidot display on newer cars - This may no longer work on some MY12 onwards cars, I tried to code a May 2012 SUPERB and a 2013 Yeti and it rejected the code... it has however worked on other 2013 cars!!)
You will need maxidot fitted to the car (as shown above) and someone with VCDS to change the country setting to Australia:
To set the country to Australia:
To change the country go to 17- Instruments and click on "Coding - 07"
Then click on "Long Coding Helper"
Finally under Bit 4 select "70 Country: Australia (AUS)"
Exit this screen and you will return to the previous screen (with the current & new coding displayed) you see that the long coding has changed, click on "Do it!" all will then be saved.
Once you have made the changes with VCDS you then need to go into the maxi-dot menu:
SETTINGS
Units
"Consu/distance" change this back to mpg (GB), mi (as it defaults to 1/100km, km),
then
SETTINGS
"MFD data" and make sure the box for Digit.speed is ticked
You can also remove the KPH display and replace it with the outside temperature:
SETTINGS
and unticked the "ALT.speed dis." box (this will remove the KPH speed and replace it with the outside temp display)
I have tried to do this but you say near the top of the email that you will need someone with VCDS to change the country setting to Australia,
I don't have VCDS only the OBDeleven dongle, I managed to change the country to Australia and in Settings it was already set to mpg (GB), mi
but couldn't find the other settings you mention.
My car by the way is a model year 2016
Thanks for your help anyway
