skoda newbie needs help!
Hello everyone.
I just purchased my first Skoda Octavia, is a 07 plate Tdi Classic with the DSG gearbox and im in need of help to sort out few niggles that are doing my head in.
First issue i had was Abs, Esp and Power Steering light on permanently on dash.
Thanks to some reading on this forum i pinpointed the fault on a worn Abs ring on rear D/S.
I replaced hub myself and as soon i drove car all dash light went off and power steering reset it itself and all fine.
I`m having issues with electrical gremlins now.
Basically the central locking switch on centre console did nothing when pressed, i replaced the switch and now works intermittently.
sometimes locks, sometime unlocks but never locks driver side door.
Actually all the electrical accesories on the driver side door (except for the electric power window) dont work.
Mirror electrical switch only operates left side not matter if i put it on L or R position, indicator on mirror doesnt work and door doesn`t lock when i press switch on inside.
Checked all fuses and cleaned the connection on door behind the Rubber but made no difference.
Being a Classic spec i dont have a remote central locking so when i lock with key door does lock and light flashes.
I have plugged it into a VCDS and i have copied and paste the findings.
If someone with more experience on the matter could help i would be very grateful.
Thanks in advance for reading this
Monday,04,June,2018,20:13:08:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 16.8.3.1
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: TMBJS21Z972063992   License Plate: KR07UMB
Mileage: 267460km-166191mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: TMBJS21Z972063992   Mileage: 267460km-166191miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 LB    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000AG  9251
   Revision: --H06---    Serial number: XXXXXXXXXXXXXX
   Coding: 0000078
   Shop #: WSC 66565 257 00032
   VCID: 6ADAFA34457FE81202-803E
1 Fault Found:
005697 - Please check DTC Memory of A/C Controller
               P1641 - 000 -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 267460 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:10:05
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.39 V
                    Bin. Bits: 00001000
                    Temperature: 38.7°C
                    (no units): 16.0
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 043     HW: 02E 927 770 AE
   Component: GSG DSG         070 1106
   Revision: 04507000    Serial number: 00000608260608
   Coding: 0000020
   Shop #: WSC 73430 790 00000
   VCID: 51A84DD8C8E93BCA63-8004
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8C7B606E7DBDBA85-806A
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1Z0 820 047 D
   Component: Climatic PQ35   010 0301
   Shop #: WSC 00000 000 00000
   VCID: 3466244C573B6EE268-8060
1 Fault Found:
00819 - High Pressure Sensor (G65)
            009 - Open or Short to Ground
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004397752
   Coding: 00880F030004140000110D000000000000097B075C
   Shop #: WSC 00675 675 00005
   VCID: 2A5A3A3485FF2812C2-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00063477
   Shop #: WSC 00675
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0T3AEJ
   Coding: 0020788
   VCID: 3D7001686471AFAA97-8068
   Subsystem 1 - Serial number: 6332MSME12124233W
   Subsystem 2 - Serial number: 6342MSME12045B5EE
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 036 0070
   Coding: 0010042
   VCID: 000EB89C53030242BC-8054
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 912 D    HW: 1Z0 920 912 D
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610058    Serial number: SKZ7Z0F3832354
   Coding: 0003401
   Shop #: WSC 80093 222 69422
   VCID: 36621E4441477CF256-8062
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001069051288
   Coding: 3F0F034007002303
   VCID: 2C563C2C8F0B362230-8078
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 26
                    Mileage: 267460 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:10:01
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1610
   Shop #: WSC 17024 576 87186
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0944
   Coding: 0000564
   VCID: 387E107C4B538A8244-806C
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
            002 - Lower Limit Exceeded
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 356019485C4177EA5F-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AH
   Component:    KSG              0401
   Coding: 19D002003F098505095B010004CC
   Shop #: WSC 17024 576 91442
   VCID: 76E2DE4401C73CF296-8022
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
1 Fault Found:
            011 - Open Circuit
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000564
   VCID: 397815787059938ABB-806C
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0034
   Revision: 00019000    Serial number: SKZ7Z3F0073327
   Coding: 0000200
   VCID: 2E523624B91744321E-807A
End-------------------------(Elapsed Time: 01:46)--------------------------
I would start by checking the wiring that goes between the body and the drivers door. Sounds like you could have a broken wire or 2 in the loom
Thanks for the reply.
Already done that last week
I have opened the door as wide as I could, pulled the rubber off and found 3 connectors.
Unplugged them and looked like water entered behind rubber because connectors had green fur on.
Cleaned everything up with electrical cleaner and inspected cables.
All seem to be ok no breakage in the wires that I could see.
I did find a blown fuse but turned out that was for the cigarette lighter and unrelated to the door issues.
Broken wires, poor connectors, corrosion could all be factors
for the sticky locks, it is worth trying to spray them with WD40 (is there a small access hole to stick nozzle in)
If the problem is mainly one door, then the window seals might be leaking, from what you have said sounds like water got in.   Open the door and poke around under the door with plastic knitting needle or wooden kebab skewer to clear any drain holes (this might have already been done, but I bet at one time there was water stuck in there)
On an 11 year old car with 267000km (about 166k miles) could be multiple reasons
Sticky locks??
I don't have any issues with sticky locks.
Car lock fine with key is when I press the central locking switch that the driver side door don't lock.
Yes I do understand that the car is old and has high mileage but I'm just trying to get to the bottom of what is causing this.
If connection is faulty why does window still works and light comes on when I open door?
Is clear that is getting power from somewhere and I find weird that electric mirror, mirror heater, central locking and indicator all failed at same time in one door.
Is there a controller unit for all this parts behind door card separate from window motor?
Edited by Super_tazio27
Mistake
