Cooling System Malfunction
Hi all....
Im a recent owner of an Octavia vRS...
And im getting a fault code of a Cooling System Malfunction, everything seems fine but b4 the light came on i got a smell of burnt water any suggestions?! it was after comin off full throttle from about 4800rpm in 4th gear...
i checked back a few pages on the forum couldnt find a similar problem, has it happened to anyone else...
the car is getting a timing belt, tensioner, dampener, water pump and general service done 2moro was mayb hoping for sum ideas.....
Cheers,
Peter.
COuld be th ewater pump giving up - in which case you're one lucky chap having it done in the morning !
P.S. What does burning water smell like ;) ?
What is the fault code number? There are quite a few related to the cooling system.
Cheers for the help lads....
the code is 4528 i think....
gonna plug it in this eve to make sure its the same fault - first incident was two days ago and then again this morn....
burnt water sounds silly when re-reading - it smells nasty!!!
Usually the fault code related to the coolant temp sensor, any idea if yours is still the black one?
I Havent dug that deep in yet... do i want the black one or not?! Was there an issue with them.....
The black dual temperature sender was problematic and has been superceded by a green one - PN 059 919 501A 4 pin green 20mm - circa £25.92
Cheers DGW...
i'll have a look....
hooked it up to another fault reader (orbit or something similar) last nite and got P1296... the book could only tell us that it was manufacture specific...
Re-connected it to the first one and came up with the same fault 4528...
well, cam-belt(tensioner, idler, damper) and waterpump r being done today, so that'll eliminate a certain few gremlins..
Later lads...
