day running lights replacing
any one replaced the day running  light/side light bulb on the updated lights on the Yeti (bottom of headlight assembly)
can.t work out how to access it
There is a rubber cover at the back of the headlight, accessible from the engine compartment. I would have tought it was via that.
(This is presuming we are talking about the facelift model)
Access by removing the cover from behind the low beam bulb. DRL/side light is located deep underneath the low beam section.
Manual says to remove the headlight. Doesn't mean you have to if access is possible.
