Error Codes - Lots of them!
Hi, My wife has a 63 plate Fabia Mk2 monte carlo 1.6TDI and has started playing up.
1st the minor issue - the fan only works on position 1 or 4, I am hoping this is something I can do myself, has anyone had this issue in the past?
The second and much larger issue is the fact it keeps going into limp mode but can sometimes drive fine. I bought a diagnostic tool and it has come up with the following:
In short its codes:
Engine:
06440
06442
07601
AND:
00907 intervention load management
00906 Horn (H1)
Full ECU report below
Any help greatly appreciated!
ECU info obtained with Carista 366099 for iOS:
VIN: TMBKL25J6E3033619
Engine
Part #: 03L906023LN
Coding: 00114016000500080000 (hex)
Component: R4 1.6l TDI
Fault codes:
06440 Manufacturer-specific code
06442 Manufacturer-specific code
07601 Manufacturer-specific code
ABS
Part #: 6R0907379AT
Coding: 43DC447D412600C3C21A226A825A00820804 (hex)
Component: ESP9.0i front
Fault codes:
00907 Intervention load Management
00906 Horn (H1)
Instrument cluster
Part #: 5J0920941K
Coding: 420A00 (hex)
Component: KOMBI
[No fault codes]
Airbags
Part #: 6R0959655K
Coding: 003243 (hex)
Component: VW10AirbagT2C
[No fault codes]
Power steering
Part #: [none]
Coding: [none]
Component: [none]
[Failed to check fault codes]
Steering angle
Part #: 6R0959654
Coding: 01 (hex)
Component: LENKW.SENSOR
[No fault codes]
Heater & air conditioning
Part #: 5J0820045D
Coding: [none]
Component: Man AC
[No fault codes]
Media player
Part #: 5N0035342G
Coding: 020100 (hex)
Component: SG EXT.PLAYER
[No fault codes]
Part #: 5JA035192H
Coding: 040004110406000001000002 (hex)
Component: RNS315-EU
[No fault codes]
Radio
[ECU not present]
Central electronics
Part #: 6R7937087P
Coding: 25980B3808C92400922008002D2B08C10000400F60000000020010000000 (hex)
Component: PQ25 BCM
[No fault codes]
CAN network gateway
Part #: 6N0909901
Coding: 232300 (hex)
Component: GW-K-CAN TP20
[No fault codes]
Immobilizer
Part #: 5K0953234
Coding: 000000 (hex)
Component: IMMO
[No fault codes]
First is (Probably) the rectifier as they fail and usually, they end up with only 4th speed coming on. There are many threads on this and they are cheap enough on eBay.
As you have noted the codes, have you thought of clearing them, removing the battery for a while and then trying things out again?
