Dubious Fuel fault codes 2.0 PD
Hi All.
Had a few issues last week with fuel codes/ Tps / fuel reg coming up, and limp home mode. Wont bore you with all the details suffice to say all looked well when checked. Eventually found that the loom where it goes over the top of the gearbox was rubbing on the bracket it was cable tied to. Not a fingers job orig factory fit, one wire broken and 3 others not looking good. I am sure I am not alone if this is std factory fit, so just post for info.
